Date/Time: Mon, 21 Apr 2025 23:30:17 +0000
Import and load Trade Activity Log Crossover
View Count: 278
[2023-02-20 10:15:27]
User756826 - Posts: 6
i am trying to load trade data to SC using crossover to run SC on Mac. I followed the instructions and can find the file to upload but it does not work. Message, no valid data found. The log I am trying to upload was created using the SC save log as functionality.
What can I do to import the data?
Beginning import of data from file: Y:\SierraChart\Data\TradeActivityLog_2023-02-17.txt | 2023-02-20 05:14:18.818
No valid data found in Intraday text file to import. | 2023-02-20 05:14:18.818 *
Regards
Thomas
imageTradeActivityLogImportLog.png / V - Attached On 2023-02-20 10:06:57 UTC - Size: 11.17 KB - 76 views
imageTradeActivityLogImport.png / V - Attached On 2023-02-20 10:07:25 UTC - Size: 28.29 KB - 84 views
[2023-02-20 10:48:56]
Sierra_Chart Engineering - Posts: 19290
When you are importing into the Trade Activity Log you need to use File >> Export from the Trade Activity Log menu to export the data first.
Date Time Of Last Edit: 2023-02-20 10:49:20
