Date/Time: Mon, 21 Apr 2025 23:33:12 +0000
Chart Shortcut Menu Feature Requests
View Count: 365
[2023-02-20 06:38:07]
User688525 - Posts: 284
Hello Sierra Chart,
I am proposing two feature requests when right-clicking on a chart (Chart Shortcut Menu):
1) "Show/Hide" Study: similar to the "Study Settings" right-click menu, this would be a "Show/Hide" option with the list of studies on the chart.
2) "Replay from Here": this would be functionality to begin a replay from a point on the chart where the user has right-clicked. For example, the user could right-click on a 5-minute bar and select "Replay from Here" which would then populate the "Replay Chart" control panel with the respective 5-minute bar time.
Is it likely that the above can or will be added to Sierra Chart in an upcoming release?
Thank you
[2023-02-20 19:57:28]
Sierra_Chart Engineering - Posts: 19290
2. We will see about this.
[2023-02-21 04:06:11]
Thank you Sierra.
Is 1) a possibility?
[2023-02-21 05:16:58]
User90125 - Posts: 715
SC Support, possible to add a similar Feature Request that shouldn't be difficult?
3) Simple update to the right-click menu for the Region Data Line for a given Study, this would be a "Duplicate" option added to the "Hide" and "Remove" options.
