Date/Time: Mon, 21 Apr 2025 23:36:07 +0000
[User Discussion] - please allow me to 'fix' indicators
View Count: 380
[2023-02-20 05:54:33]
User740271 - Posts: 12
I want to terminally fix indicators on the chart. This means these indicators will not move even if I 'grab' them unintentionally while I a moving the chart around.
Now, I work on indicators, then later, I grab for the chart, but by happenchance I grab the indicator, and now this indicator which I happen to grab moves. I just lost all the time I spent initially spent setting this indicator.
Is there a way to fix indicators?
Thank you.
[2023-02-20 06:01:44]
Sierra_Chart Engineering - Posts: 19290
Do you mean changing the scale for a study on the right side of the chart?
Otherwise, it is not possible to be moving a study around in its region.
[2023-02-20 06:03:30]
Actually we realize you can change the vertical scale using the Hand tool anywhere on a chart but there is a setting to disable that in Global Settings >> Tool Settings.
By default this is disabled.
[2023-02-20 20:36:01]
John - SC Support - Posts: 39395
It sounds like you are referring to Chart Drawings, not an indicator. Refer to the following for how to lock a drawing:
Chart Drawing Tools: Locking Chart Drawings
