Date/Time: Tue, 11 Mar 2025 05:08:00 +0000
New Data Service: TeleTrader. European and Global Markets Coverage
View Count: 2946
[2014-06-11 18:48:02] |
Hello, To further increase the coverage of exchanges available to Sierra Chart users, we have added support for the TeleTrader data service. To use this service, follow the instructions here: http://www.sierrachart.com/index.php?l=doc/TeleTrader.php You will need to update Sierra Chart to the latest prerelease with Help >> Download Prerelease to use TeleTrader. If you are an Interactive Brokers user trading the European markets, we can map the data from TeleTrader to the IB trading service so you can use good quality data and trade from Interactive Brokers. We just need to know what symbols you want to have mapped. We cannot do the mapping for the EUREX though. This is already mapped to the Sierra Chart EUREX data feed. And it is not possible to set up 2 mappings for a symbol for a trading service. To use TeleTrader EUREX data you need to use the TeleTrader service independently. You can always install a second copy of Sierra Chart on your system to use TeleTrader if you are using another trading service. Here are instructions for that: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
