Date/Time: Mon, 21 Apr 2025 23:27:28 +0000
ACS Control Bar Button # for Enable/Disable text reset on each studies
View Count: 502
[2023-02-17 17:16:22] |
BenjFlame - Posts: 337 |
I have several "Study Controlled Targets and Stops" that are enabled / disabled by ACS Control Bar Buttons in a control bar. When I take the time to label each of these button to a suggestive name.... each time I "Apply" changes to a study (any study) it reset the text of all those buttons to "TMS". I don't think this is an intended behavior. |
[2023-02-20 15:02:15] |
Sierra_Chart Engineering - Posts: 19290 |
With the Trade Management by Study study, you need to set this Input to Yes: "Allow Custom 'Properties' for Control Bar Button" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-20 15:02:42
