Date/Time: Mon, 21 Apr 2025 23:27:30 +0000
DTC - Price1 not precise
View Count: 303
[2023-02-17 08:36:18] |
User251043 - Posts: 47 |
Hi, I'm writing a DTC Server and using SC as the client. I sent a Limit order at price 24400. I sent it from the trading panel. But when I review the DTC messages I find that SC is setting 'Price1' to 24399.9994546175 instead of 24400, what is forcing the server to make some extra calculations. How can I setup SC so it sends the order at $24400, and not at $24399.9994546175? Thank you |
[2023-02-17 12:01:41] |
Sierra_Chart Engineering - Posts: 19290 |
There is not a way to solve this. It has to do with floating-point error at the level of the CPU. You will need to round off the value to the nearest integer in this particular case. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
