Date/Time: Mon, 21 Apr 2025 23:30:23 +0000
Enabling compression for file: TICK-NASDAQ.scid. This may take a while
View Count: 314
[2023-02-17 05:08:30]
Bedhog - Posts: 180
I've installed SC on a new Windows 11 machine and these 2 lines are scrolling endlessly in the event log.
File compression enabled. S:\SierraPRE\Data\TICK-NASDAQ.scid. CompressionState=0 | 2023-02-16 23:05:36.733
Enabling compression for file: S:\SierraPRE\Data\TICK-NQ.scid. This may take a while. | 2023-02-16 23:05:36.734
These 2 files are not growing or shrinking.
Suggestions?
Thanks in advance.
imageeventlog.png / V - Attached On 2023-02-17 05:07:39 UTC - Size: 20.59 KB - 79 views
imagescidfile.png / V - Attached On 2023-02-17 05:07:52 UTC - Size: 2.64 KB - 76 views
[2023-02-17 11:18:23]
Sierra_Chart Engineering - Posts: 19290
That is very unusual and unexpected. We are not sure what the cause is. It is not something which should normally be seen.
Our recommendation is to disable file compression through Global Settings >> Advanced Service Settings.
