Date/Time: Tue, 26 Nov 2024 19:38:42 +0000
Alert sounds lag
View Count: 977
[2014-06-11 17:53:47] |
Leo33 - Posts: 73 |
I set up alerts on two studies one click sound on LAST=BID a different click sound on LAST=ASK The sounds lag the market and back-up [cue-up]. I understand alerts where not designed for this kind of rapid firing :) I also tried some custom code to fire off the alerts. Same lag. Is there a way round the lag? A way to fire of rapid sounds from code or otherwise? |
[2014-06-12 17:03:10] |
No way around this unless you interact directly with the Windows API to play sound files.
[2014-06-12 18:04:52] |
Leo33 - Posts: 73 |
ok thanks. edit::[ahh..forgot about not replying if solved] Date Time Of Last Edit: 2014-06-12 18:06:40
