Date/Time: Mon, 21 Apr 2025 23:27:24 +0000
intraday time frame
View Count: 450
[2023-02-16 20:55:59] |
User188930 - Posts: 3 |
sorry is the TPO PROFILE CHART not working on intraday time frame
[2023-02-16 23:33:26] |
TPO profiles can ONLY be used on Intraday charts. We are not sure exactly why you are having an issue, but it could be related to your account not being an "Activated Trial". As a standard trial, you only have access to certain data and the amount of data is limited. We have gone ahead and set your account to be an "Activated Trial". If you continue to have issues, then let us know. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-19 13:17:21] |
Hi when I apply TPO PROFILE CHARTS to intraday, it does not work,only works on daily, weekly, monthly, if im on 60 minutes charts and I select tpo profile chart,,,,it goes back to 1 day |
[2023-02-19 18:00:01] |
Sierra_Chart Engineering - Posts: 19290 |
The TPO Profile Chart study can be used on Historical Daily charts, but the chart data that is required, is automatically managed by the study and will be changed as required. It is not anything you control directly.
[2023-02-19 19:45:05] |
what do you mean by " is automatically managed by the study",,,,so can I use TPO PROFILE CHARTS for intraday or not?
[2023-02-19 21:14:39] |
Yes you can use them on Intraday charts. That is normally the data that is used.
[2023-02-20 19:42:40] |
Just note that the default setting for a TPO chart is 1 day, which is why you are seeing 1 day of data per TPO profile. You can change this using the following Input and the one after it: Time Price Opportunity (TPO) Profile Charts: Profile Time Period Length For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
