Date/Time: Mon, 21 Apr 2025 23:36:10 +0000
Strange Teton Routing Error this morning
View Count: 427
[2023-02-16 18:27:05] |
User414522 - Posts: 19 |
Woke up this morning to a Service Connection Error Pop up: "Logon error received from server: Secondary instance is not allowing connections to this server." What does this mean? I do not use the instance feature in Sierra Chart and I run everything from the main instance. Please advise. Thanks!
[2023-02-16 22:33:46] |
Sierra_Chart Engineering - Posts: 19290 |
You can safely disregard that. That is the backup Teton order routing server that got connected to due to a connection problem you had to the primary server. The backup server is not allowing connections unless the primary server is down.
