Date/Time: Mon, 15 Dec 2025 09:10:57 +0000
Drawing VPOC with DVP tool
View Count: 512
[2023-02-16 18:17:45]
ssangha84 - Posts: 129
Hello, I was wondering if there’s a way to automatically draw a horizontal line at the VPOC on the DVP tool so that the horizontal line shows up on all charts? I know you can highlight the vpoc in the tool itself, but was wondering if you can automatically have a line drawn out on all charts. Thanks.
[2023-02-16 22:30:28]
John - SC Support - Posts: 43443
The way to get the VPOC from any Volume by Price profile (doesn't matter if it is Drawn or not) to another chart, is to use the Study/Price Overlay study. When you overlay a VbP from another chart, you only get the VAH, VAL, POC, and VWAP lines. Therefore, you can hide the VAH, VAL, and VWAP if you do not want them.
The down side of this is that you can not specify a Drawn Profile Study ID in order to try and "line up" the Study/Price Overlay to pick up the information. So you would have to draw the profile, then you can set the Study/Price Overlay to reference that study.
Refer to the information for the Study/Price Overlay here:
Study/Price Overlay Study
