Date/Time: Wed, 27 Nov 2024 02:30:04 +0000
Documentation Printable
View Count: 1219
[2023-02-16 17:19:57]
User303857 - Posts: 74
Hello Sierra, I see this link for documentation.
You can download an offline copy of the documentation.
https://www.sierrachart.com/downloads/SierraChartDocumentation.zip
Is there a printable PDF or Document, that I can read without looking at a screen?
Would like to print the entire thing, and eventually read it all.
There are so many sections & subsections in the web page version, so printing would be a task.
Thank You
[2023-02-16 22:11:11]
John - SC Support - Posts: 36309
Sorry, but we do not have a PDF version of the documentation. Just the one option to download as you have found.
[2023-02-16 22:14:34]
You had us curious if there was a Website to PDF converter, and in doing a quick Internet search, there are a few. So you might want to look to see if you can find something that will work for what you want.
[2023-06-29 23:32:10]
Hello Support, well I have just read the entire documentation on Charting.
Next is to read all of the Studies and Indicators, Trading & Technical Studies Reference.
I was able to convert all of the online web pages into PDF format.
But, the very annoying problem is that , the font is too small and difficult to read, it prints at about 8 point or less.
And my eyeballs are having a margin call.
No, print shops have been able to increase the font size without making a mess out of all the graphics & borders , layouts....
PDF will just not cooperate.
Is there anyway you can make available the manual in a .doc format so that the font can be eligible when printed?
You must have created it in something other than web format at some point.....
Thank You
[2023-06-30 13:02:35]
Actually, the documentation is only in web format. Our general principle is to keep things as original as possible to avoid any extra processing.
Therefore, we do not have it in any other format.
[2023-06-30 13:34:40]
Sierra_Chart Engineering - Posts: 17190
There actually is a single page version of the documentation. We have to find the link for that.
[2023-06-30 16:05:51]
[2023-06-30 20:41:54]
Already have that, that is what I used to make the PDF manual out of...
Already have a complete PDF of all of those pages.
Not wanting to read a computer screen for months on end ... would rather read off of paper with 12 point font.
Don't understand how a .doc file for download is avoiding extra processing....
But let's be clear on one thing >>>
90% or more of the problems posted on the support board can be solved by reading the manual.
So, in reality , actually, you are creating more work for yourselves & wasted time by not having such a document easily available.
Regards
[2023-07-01 18:42:14]
We will look this over.
[2023-07-01 21:09:28]
I will make do, I know there are more important tech problems to manage on a daily basis for your team.
I did convert a PDF to a .doc online it mostly worked but has some blank space areas on the pages , but all of the info & images looks like they are there.
But , I am using open office to open the file , and do not have word, so that could be causing the added white blank space added.
I can send you all of the converted PDF files from the zip file if you want those just let me know? How to do that.
It might have to be a google drive or I could get drop box...
I have the:
CHARTING
STUDIES and INDICATORS
TRADING
TECHNICAL STUDIES REFERENCE
Thanks Again
Date Time Of Last Edit: 2023-07-01 21:16:21
[2023-09-23 18:36:51]
User509909 - Posts: 1
I also see advantages to read it in paper. I have converted the documentation as it was yesterday to pdf, and adjusted margins and font-size and some other things to increase the readability and space of the print. It can be refined but I think is enough.
Essentially I have downloaded the documentation and changed the css web styles and passed it to wkhtmltopdf. I can share the pdfs files or the process of how I did it if someone is interested. I think it could also be done with a documentation generator like pandoc or sphinx, but are more complex tools that wkhtmltopdf, and would require more work to build a first setup generator, but would output a more polished document.
About the problem of small font that User303857 talked about, I found it was produced in my case because there are some images with a big width, so the converter from html to pdf reduces the font size as what seems a way to adjust the general width so the image is included without being cut. I solved it in the css styles setting a img{max-width:100%}.
The total page count I obtained in pdf from the complete documentation is 3565 pages with this distribution of number of documents and pages:
1.- Getting Started: 10 documents / 37 pages
2.- Charting: 27 / 495
3.- Studies and Indicators: 18 / 486
4.- Trading: 25 / 667
5.- ACSIL: 21 / 573
6.- Spreadsheets: 10 / 141
7.- Settings Windows: 11 / 163
8.- Menu Commands: 11 / 78
9.- Managing Symbol Data: 11 / 65
10.- External Interfaces: 22 / 233
11.- Help - FAQ: 49 / 191
12.- Supported Data and Trading Services: 27 / 245
13.- Support Pages: 3 / 11
14.- Other Pages: 23 / 136
15.- Sierra Chart Account Management: 6 / 29
Date Time Of Last Edit: 2023-09-23 20:33:53
Private File
Private File
[2023-09-23 23:48:58]
I did get most of it converted, but it sounds like you had better formatting options. A few of the chapters/sections printed in very small font like 6 or 8. And, a lot of the pages cut off a few lines at the bottom of the pages.
What I did print , I did so in black & white, a lot cheaper at the print shop.
Adobe pdf is the worst for printing, and trying to convert it to word format, I like paper ,but might be better with a Kindle or something.
I sent you a dm , I would like to see/get your version , it sounds better than what I created... but I have read Trading and Charting so far.
I think next I will read Studies and Indicators.
And also Steidlmayers Market Profile, six part study.
