Date/Time: Mon, 21 Apr 2025 23:27:32 +0000
Real Time Data
View Count: 343
[2023-02-16 16:46:00]
User785755 - Posts: 1
After a while, the current price does not reconcile with the chart. Please see copied image. I have restarted the program and reset connection. Thanks again.
https://www.sierrachart.com/image.php?Image=16763939162.png
Thank you.
[2023-02-16 18:54:03]
John - SC Support - Posts: 39395
Check your Session Times and make sure they are set to cover the full range of the trading day. Refer to the following:
Chart Session Times
