Date/Time: Mon, 21 Apr 2025 23:33:08 +0000
denali data feed
View Count: 345
[2023-02-16 16:44:54] |
User972463 - Posts: 1 |
Hello, I tried to open a live GFF Brokers Futures Account, when I contacted the support client, I was told that they do not support sierra chart with denali datafeed. I would like to get the list of brokers that support Sierra Chart WITH Denali data feed for future live account. Because some broker support Sierra Chart but not support Denali datafeed Thank you in advance, and I remain at your disposal for any further information Cordially |
[2023-02-16 18:46:11] |
This statement is impossible. The broker has no control over the data that is used for Sierra Chart. Therefore, if the broker supports Sierra Chart, then you can use Sierra Chart with the Denali Exchange Data Feed. The one thing this could mean is that the broker is not going to allow you to stop paying for the data from the trading service they set you up with. But we do not know for sure. --- Regardless, we recommend using a broker that supports our Teton Order Routing Service. You will find the list of these brokers at Step #2 at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions Otherwise, you will find a list of supported brokers using either CQG or Rithmic for order routing at the following link: https://www.sierrachart.com/index.php?page=doc/OtherSitesLinks.php#Brokers For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
