Date/Time: Wed, 27 Nov 2024 18:53:08 +0000
Possible to run datafeed from AMP and continue to use denali?
View Count: 416
[2023-02-16 16:44:40] |
User288938 - Posts: 35 |
Hello! So I have amp setup to use sierra charts and denali data feed, but im looking to trade on the HKEX. Is it possible to buy the data from amp get them to set it up on their and continue to run denali with sierra charts? Without having to pay the $50 month on sierra charts, instead I would just pay the 15$ a month through amp? Just dont want to pay $50 a month for instruments I need to test etc. THank You! |
[2023-02-16 18:41:32] |
John - SC Support - Posts: 36335 |
Yes, you can do this for the HKEX data. We just do not support data for the CME Group and EUREX from CQG.
[2023-07-10 22:45:35] |
User113114 - Posts: 5 |
Hi @User288938 Did you end up being able to get the HKEX data feed working? I have set up the same scenario, however I cannot load expired contracts. Have contacted support about this and CQG support the data however it seems to be a compatibility issue with Sierra Chart/CQG data. Did you manage to view expired contracts for HKEX? Cheers |
[2023-07-10 23:06:43] |
Update, I have found this older thread explaining the issue and that Sierra cannot provide a solution for this, for anyone also investigating the issue: Is Sierra not requesting full duration of CQG provided tick data even when available? Will have to find another solution to trade HKEX unfortunately. |
[2023-07-11 02:02:17] |
Sierra_Chart Engineering - Posts: 17198 |
This is because CQG does not provide this data through the CQG Web API.Have contacted support about this and CQG support the data however it seems to be a compatibility issue with Sierra Chart/CQG data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
