Date/Time: Mon, 21 Apr 2025 23:33:10 +0000
Symbol missing
View Count: 390
[2023-02-16 13:17:20] |
like2trade - Posts: 117 |
The following Bitcoin symbol is available when the Data/Trade Service Setting is SC Data - All Services, but it is not available when it is Interactive Brokers: BTC-PERPETUAL-DBIT |
[2023-02-16 17:41:18] |
This is definitely not something we are going to implement support for when using Interactive Brokers. Install another installation of Sierra Chart for this by following these instructions: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-17 05:48:39] |
After looking into this further, when going to File\Find Symbol under "Available Symbols" the entire "Deribit" feed is missing when the Data/Trade Service Setting is Interactive Brokers, whereas it is visible when the Data/Trade Service Setting is SC Data - All Services. The symbol BTC-PERPETUAL-DBIT, happens to be part of Deribit. |
[2023-02-17 15:19:59] |
That is correct. This why you need to install a second copy of Sierra Chart which has the service set to SC Data - All Services and then you will have access to that data in that installation.
