Date/Time: Mon, 21 Apr 2025 18:13:42 +0000
Anyway to keep detached chart windows on the list of chart tabs?
View Count: 325
[2023-02-16 01:28:27] |
User1293821 - Posts: 42 |
Is there anyway to keep a detached chart windows on the list of chart tabs in the main window? I overlap multiple charts to keep them large and then click the tab I want to see.
[2023-02-16 15:06:05] |
John - SC Support - Posts: 39380 |
There is not a way to do this. But, the detached charts are listed in the CW menu, so you could access them through there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
