Date/Time: Mon, 21 Apr 2025 17:34:52 +0000
Custom VWAP Formula
View Count: 409
[2023-02-16 01:20:16] |
User531259 - Posts: 2 |
Hello, I'm trying to see if there's any way to combine the VWAP of two different futures currencies using a specific formula and creating a new VWAP with the sum of those two VWAP to be displayed on a different chart. |
[2023-02-16 15:03:32] |
John - SC Support - Posts: 39380 |
Yes, this can be done. Refer to the arithmetic studies here: Using the Basic Arithmetic Studies Or, if your formula is more complex, then consider the Spreadsheet Formula study. Note that this study uses the Alerts syntax: Spreadsheet Formula And for even more complicated calculations, you can use the Spreadsheet Study: Using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
