Date/Time: Mon, 21 Apr 2025 17:40:45 +0000
Array unallocated message (lots of them)
View Count: 391
[2023-02-16 00:07:05]
User912281 - Posts: 18
I have searched online and found the same topic brought up a number of times but none I could find with a response.
When I log in to Sierra Chart I receive numerous occurrences of the following message line, with no apparent resolution:
"Array unallocated...{with dates and times}"
I can provide the message log if needed.
Thank you!
[2023-02-16 14:59:02]
John - SC Support - Posts: 39380
This generally does not cause an issue, and it is hard to figure out where it comes from.
Please copy and paste a few of the lines where this occurs, particularly the few lines just above and a few of the actual error lines. We'll see if there is any information that can point us at where this is coming from.
We work hard to try and not have these kind of things occur (but they do occasionally), but if you are using any customs studies, then those would be the first items to check, by removing them from your charts and seeing if the messages go away.
