Date/Time: Mon, 21 Apr 2025 17:40:46 +0000
Highest High Lowest Low display
View Count: 378
[2023-02-15 21:37:22] |
Carol Rutherford - Posts: 66 |
How do I display the price instead of a line using the Highest High Lowest Low number of bars study?
[2023-02-15 22:14:55] |
John - SC Support - Posts: 39380 |
The first option is to use the Value Label to display the price. Refer to the following: Chart Studies: Subgraphs Tab >> Name and Value Labels Another option to have a larger display that you can place anywhere, would be to use the Text Display for Study study. Refer to the information here: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
