Date/Time: Mon, 21 Apr 2025 17:46:50 +0000
DeltaMomentum (Source Code)
View Count: 413
[2023-02-15 20:34:59] |
Ragy - Posts: 29 |
Hello Can someone from Sierra Support send me the source code for the "DeltaMomentum". It is under User Contributed Studies (UserContributedStudies.dll v2244). Date Time Of Last Edit: 2023-02-15 21:04:48
[2023-02-15 21:34:39] |
John - SC Support - Posts: 39380 |
The source code we have for the User Contributed Studies is at the following link: User Contributed Advanced Custom Study System Source Code We do not see anything for DeltaMomentum, but it's possible that the name of the study is different from the name of the file. You can look through and see if you can find something that may be the DeltaMomentum file by having a similar name and then download the file and look at the sc.GraphName to find the name that is used within the software. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-15 22:12:00] |
Ragy - Posts: 29 |
I was able to find it in the link below in case someone else is looking for it. https://www.sierrachart.com/AdditionalFiles/UserContributedACS_SourceCode/UserContributedStudies.cpp |
