Date/Time: Fri, 29 Nov 2024 10:35:38 +0000
Feature Request - Support for Market Depth Historical Graph Study on Trade DOM
View Count: 431
[2023-02-15 18:51:18] |
AC7303484 - Posts: 26 |
I would like to add the Market Depth Historical Graph study to my Trade DOM and see that it is not in the available study settings list. Would it be difficult to add support for this? I can see this being extremely beneficial for many. I posted an example of what I would be looking for. |
Attachment Deleted. Untitled design (7).png / V - Attached On 2023-02-15 18:50:35 UTC - Size: 124.89 KB - 102 views |
[2023-02-15 21:20:46] |
We have noted your request to have the Market Depth Historical Graph on the Trading DOM. Just keep in mind that we can not say when we will get to any particular feature request. Also - we do not understand the image you provided relative to the Market Depth Historical Graph. The image shows 2 Volume Profiles in the Trading DOM, one of which is showing Ask Volume - Bid Volume. This can be done with the tools you have available now. And we do not see anything related to the Market Depth Historical Graph. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-15 21:42:28] |
ticinotrader - Posts: 392 |
@AC7303484 FYI: This (displaying the historical depth levels + DOM together) is doable using the built-in functions of Sierrachart. You just need to use and properly configure a chart with the Market Depth Historical Graph that displays the Chart DOM - instead of trying to overlay the historical depth on the DOM. See the attached screenshot for an example. This chartbook is available for a long time at the below link, so not a new feature: https://www.ticinotrader.ch/advanced-volume-filtered-volumeprofiles-for-cl_f-and-zn_f/ You can create it on your own as well. Hope this helps. |
_20230215_223310.png / V - Attached On 2023-02-15 21:41:10 UTC - Size: 231.94 KB - 87 views |
[2023-02-15 22:04:59] |
John, Apologies for the additional info on the screenshot. Disregard the 2 volume profiles. I am only wanting to be able to add market depth historical graph to a Trade DOM. Thanks for the consideration! Date Time Of Last Edit: 2023-02-15 22:50:15
