Date/Time: Mon, 21 Apr 2025 18:04:49 +0000
Global Data feed India
View Count: 416
[2023-02-15 15:35:21] |
User505195 - Posts: 1 |
Requesting to enable the Global Data feed India for my trail version. Thanks
[2023-02-15 17:24:15] |
John - SC Support - Posts: 39380 |
We have set your account to be Package 12, which gives you the same capabilities as the Trial, except that you can now get the real-time data. Refer to the information for Global Data Feed at the following link: Global Data Feeds (India) Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
