Date/Time: Tue, 26 Nov 2024 19:55:15 +0000
Scheduling connection to Data server
View Count: 996
[2014-06-11 03:08:38] |
WrldTrdr - Posts: 2 |
My service 'Global Data Feeds' server is turned on only during market hours, I have to manually select disconnect and connect each day, Is there any method to schedule the connection time to server? |
[2014-06-11 06:10:28] |
Select Global Settings >>Data/Trade Service Settings. Enable the Connect on Program Startup and Reconnect on Failure options. Once you connect, Sierra Chart will continue to try to maintain the connection. When the Global Data Feeds server becomes available, then it will connect at that time automatically. The only disadvantage of this, is that the Message Log will open up when there are failures to connect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-12 07:13:29] |
One additional disadvantage is problems in connections to the GDFL server because of frequent connection attempts, hope they fix it soon. |
