Date/Time: Mon, 21 Apr 2025 23:30:22 +0000
Chart-Values Crosshairs/ Compact Tool Values Window on a Flex Renko Inverse
View Count: 515
[2023-02-15 13:21:35] |
User871209 - Posts: 91 |
Hello, When I use the Chart/Values Crosshairs show Compact Tool Values Window on a Flex Renko Inverse chart it doesnt show me the H/L prices. Is there an option to activate to be able to see these? Please let me know, Thank you, Regards, |
Attachment Deleted. ![]() |
[2023-02-15 16:10:31] |
Refer to the following setting: Chart Settings: Settings Button (Chart >> Chart Settings >> Display >> Chart Values menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-15 16:31:39] |
John, Thank you for your reply, I have them selected but doesn't display the info. In my regular chart candles stick chart however does display the info. Any other selection I May be able to attempt to fix the issue? |
[2023-02-15 18:09:46] |
If that graph is not in Region 1, then check the following setting: Chart Drawing Tools: Compact Tool Values Window Shows Chart Region 1 Values Only (Tool Settings >> Chart Values >> Chart Values) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-16 04:23:00] |
I do have the settings as specified in the link sent but it doesn't work. I have a regular candlestick chart open for (daily, 4hrs) and on these the Chart/Values Crosshairs show Compact Tool Values Window perfectly. I took this chart which is a regular candlestick that does show the values and changed the settings to Flex Renko Inverse and it then does not show the Chart/Values Crosshairs / Compact Tool Values Window. Could it be that if the chart is a Flex Renko Inverse it does not show the values? |
[2023-02-16 15:22:10] |
We are able to view the information for a Flex Renko Inverse chart, using the same settings that you had, so this is not the issue. Please get us your chart by following these instructions and we will see if we can reproduce and figure it out: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-16 15:48:08] |
John, I have attached the chart to this message, Thank Yoo! |
[2023-02-16 18:32:52] |
You have the Heikin-Ashi study set as the Main Price Graph and then on the Subgraph tab for that study you have the option for Display Study Subgraphs Name and Value - Global disabled. This is preventing the display of the information. If you enable that option you will be able to see the information. Refer to the following: Chart Studies: Subgraphs Tab >> Display Study Subgraphs Name and Value - Global For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-16 21:06:48] |
John, A thousand thanks, worked perfectly with adjusting this setting. THANK YOU! |
