Date/Time: Mon, 21 Apr 2025 17:40:46 +0000
SierraChart not showing same levels as other feeds
View Count: 353
[2023-02-14 15:22:49] |
DaveInMT - Posts: 4 |
My SC (Denali feed) shows ES price levels from 10 to 20 points lower than TastyTrade and Bookmap on TOS. Trading View is the same as SC. SC/TV appear to be delayed. All are for the March contract. Thanks
[2023-02-14 16:36:13] |
John - SC Support - Posts: 39380 |
You are not setup to get any real-time data from us, therefore you are getting delayed streaming data. You have everything setup except you did not activate any exchanges. You can activate the exchanges you want for the CME Group at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-14 16:52:57] |
Thanks so much. I was obviously confused at setup!
