Date/Time: Mon, 21 Apr 2025 17:34:51 +0000
Some Charts wont load with new Teton CME data feed
View Count: 346
[2023-02-14 14:44:42]
User148596 - Posts: 217
Hi, I just switched over to Teton CME data and now all of my charts for ES wont load past a certain date but I can't change that date in data limiting under chart settings. All of my NQ charts loaded fine with the new data feed. The current symbol for the ES charts is ESH23_FUT_CME which I believe is correct.
Any support would be appreciated.
[2023-02-14 14:55:18]
Sierra_Chart Engineering - Posts: 19289
In the case of a Continuous Futures Contract chart, first re-download the data:
Also refer to:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
[2023-02-14 15:02:30]
Thank you, I had done all of that and the charts were still not loading but I guess they were just taking a while to load a couple of charts (only 90 of historical data so not sure why it was taking so long) but everything is working properly now.
Thanks and apologies for the confusion.
