Date/Time: Tue, 22 Apr 2025 02:18:38 +0000
Changing the quantity for BTC orders
View Count: 385
[2023-02-14 11:56:39] |
User251043 - Posts: 47 |
Hello, I'm trying to modify an open order for BTC. I can place an order (i.e. 0.14BTC), but when I want to modify it on the chart, the window that spawns (small "Quantity and Price" window) only allows me to input integers. I type the new quantity but I need to press "A", and when I do that it changes the quantity to integers. Where can I modify the settings so the quantity window allows me to introduce decimals? Thank you |
[2023-02-14 13:00:50] |
Sierra_Chart Engineering - Posts: 19290 |
We have to make a change to support this. We will work on that.
[2023-02-17 20:22:57] |
This will be out in the next release.
[2023-02-17 22:45:44] |
Great! Thank you very much!
[2023-02-27 10:26:09] |
Hi, I reviewed the 2483 pre-release. You included what we talked about in previous posts. Thank you! As a suggestion for future releases, it would be great if the buttons in the Trade Window (the ones numbered 1-6) could be programmed with decimal numbers. In addition, the quantity in "Targets" tab do not accept decimal numbers either. Well, there's a "workaround": if you place the decimal number in the Main tab's quantity, and then add a new target, the decimal quantity is accepted, but you cannot modify it directly in the Targets tab (you cannot even type a dot there). Anyway, thank you very much for your work, guys. |
