Date/Time: Mon, 21 Apr 2025 17:46:50 +0000
Total Volume - Numbers Bars Calculated Values
View Count: 459
[2023-02-14 02:51:19]
User687593 - Posts: 6
Hi There ...!
I', having some trouble to understand the logic behind calculating Total Volume Percentages using the Numbers Bars Calculated Values.
Inputs:
Determine Maximum/Minimum Values for Background: Daily
Session Time Start : 21:00:00
Session Time Ends: 20:59:59
Percentage compare threshold: 0.25, 0.50, 0.75
Range Colors: attached
Then the question is why values like 270, 232 296 as rated as less than 25%, if the max value is 523 ?
Thanks for your support.
imageTotal Volume.PNG / V - Attached On 2023-02-14 02:49:48 UTC - Size: 4.46 KB - 100 views
imageRanges.PNG / V - Attached On 2023-02-14 02:49:58 UTC - Size: 8.18 KB - 98 views
[2023-02-14 12:59:32]
Sierra_Chart Engineering - Posts: 19289
Are you sure that is the maximum volume value? What is the minimum volume for the time period?
Date Time Of Last Edit: 2023-02-14 12:59:49
[2023-02-14 15:56:49]
John - SC Support - Posts: 39380
The easiest way to find the actual highest value for the time period is to set your Percent Compare Threshold values to something like .25, .5, .99, this way only values that are greater than 99% of the maximum value will be highlighted with the Range 3 Up color. And since you already have this color set to something that will stand out, you can easily scroll through to find the actual maximum and then see how that aligns with the values you have in question.
Just do not forget to change your Percent Compare Thresholds back to your standard.
[2023-02-14 18:44:52]
Good point, and that advise really helped me understand the logic behind.
Thanks for your support, it's all clear now !
