Date/Time: Mon, 21 Apr 2025 17:46:49 +0000
Possible Feature Request Numbers Bars Scaled to X Bars vs all visible
View Count: 351
[2023-02-14 02:06:20]
TopGunTrader - Posts: 191
I can never get my footprint charts aka Numbers Bars to scale right. I typically leave it bar by bar because when all visible is on there is typically one bar back that has 10x more volume and that messes up all the rest.
It would be wonderful to have option of X Bars Back. So for ES 1 min bars I might want to see 5 bars but want it scaled to last 15 or 30 depending on time of the day.
I'm sure 30-50% of your Numbers Bars users would appreciate this as well.
On a side note is there away to make a Sierra Chart always on top?
[2023-02-14 15:27:37]
John - SC Support - Posts: 39380
We have noted your request, but we can not say when we would implement this.
With regards to Sierra Chart always on top - this option is not available for the main program, but if you detach a chart window, then that chart can be set to "Always on Top". Refer to the following:
Detaching and Attaching Chart Windows
