Date/Time: Mon, 21 Apr 2025 17:34:53 +0000
Volume at Price Threshold v2 - Only highlight for multiple consecutive AskBid differences
View Count: 355
[2023-02-14 01:46:21] |
Cprice253 - Posts: 1 |
Hello, Is there any way to add a threshold amount of consecutive Ask or Bid diagonal imbalances that are highlighted via extension lines? For example (see attached chart), I have extended highlights set up for Ask and Bid diagonal imbalances over a certain % threshold, but I only want 2 or more consecutive imbalances to be highlighted instead of single instances. Please let me know if this makes sense or if I a misunderstanding the functionality of the study. Thank you. https://www.sierrachart.com/image.php?Image=1676338973699.png |
[2023-02-14 15:25:01] |
John - SC Support - Posts: 39380 |
The Input for Highlight Adjacent Alerts Minimum Group Size gives you a way to view when you have a stacked imbalance. Refer to the specific instructions for this here: Volume at Price Threshold Alert V2: Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance) You can then set the Draw Extension Lines to All Prices in Adjacent Alerts to get the extension lines for the stacked imbalances. Refer to the information for the Inputs for the study here: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
