Date/Time: Mon, 21 Apr 2025 17:34:52 +0000
Can I display hundred charts in tile format?
View Count: 534
[2023-02-13 23:50:32]
User799255 - Posts: 24
I am currently streaming equities data using IQfeed and Amibroker but looking to save a bit and it looks like if I signup to package 10 that includes Denali live feed and additional NASDAQ feed I can get the same information at around 50 dollars a month, which is more than 50% off. What I am curious is how efficiently SC handles displaying and streaming charts.
Attached shows how I've currently set up in Amibroker. It displays more than hundred per screen I have for 30min bars. Can I replicate something like this in SC ?
Thank you very much.
imageCapture1.PNG / V - Attached On 2023-02-13 23:49:24 UTC - Size: 474.58 KB - 110 views
[2023-02-14 02:01:25]
Sierra_Chart Engineering - Posts: 19289
Yes:
We have activated your trial. You can test this now.
Use this data feed:
Delayed Exchange Data Feed
You should also learn about Chartbooks:
Chartbooks (Workspaces)
Date Time Of Last Edit: 2023-02-14 02:01:41
[2023-02-14 22:29:44]
Thank you for activating the trial and the info on chartbook. I have set up the feed, charts and learnt to duplicate the existing template via duplicating charts. So far so good. One question I have is - how can I remove or minimise the menu bars from individual windows to utilise the space more efficiently. (screenshot attached)
Same problem I had with Amibroker but I could simply add additional chart symbols as multiple indicators and save space. Can I do that here?
Thank you
imageCapture1.PNG / V - Attached On 2023-02-14 22:26:28 UTC - Size: 282.42 KB - 106 views
[2023-02-14 23:48:06]
John - SC Support - Posts: 39380
For each chart, select Chart >> Show Title Bar to remove the checkmark next to that option. That will then remove the Title Bar. Refer to the following:
Chart Menu: Show Title Bar (Chart menu)
