Date/Time: Mon, 21 Apr 2025 17:43:43 +0000
Changing color #s
View Count: 375
[2023-02-13 21:46:46] |
User123891 - Posts: 20 |
When I draw a box or marker on a chart, and you hit color, a box pops up and gives eight colors to choose from numbered #1 -#8. How do I change the colors in that box without having to do so through chart properties every time? For example, right now black is not an option for me. How do I change color #8 which is currently white and useless to me on my white background charts to black. I have searched and searched and not found this answer. Thanks
[2023-02-13 23:00:13] |
John - SC Support - Posts: 39380 |
Refer to the following: Chart Drawing Tools: Customizing Colors on the Menu For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-13 23:21:27] |
Thank you for your prompt and helpful response.
