Date/Time: Tue, 26 Nov 2024 20:00:47 +0000
automatic trading
View Count: 1025
[2014-06-10 17:20:53] |
User14740 - Posts: 11 |
Dear Mr/Miss I would like to have assistance on the following subject. In my Sierra chart I draw lines. I have set alert sounds on my lines. As soon as my line is hit I hear the sound of my choice, so that I can go into a trade. But so far I have to do all that by hand. I want the trade to start automatically as soon as the price of my choice is reached and hits my line, also when I am not there. So my question is: How can I activate my alert lines and start the trade with the number of contracts of my choice? Thank you in advance. Kind regards, Peter van Soest |
[2014-06-10 20:43:03] |
This is not supported unless it is custom programmed and it is not easy to program this.
