Date/Time: Mon, 21 Apr 2025 17:43:43 +0000
Strong Suggestion - Small but Important Platform improvement.
View Count: 440
[2023-02-13 20:05:39]
User708541 - Posts: 135
I spent over 1 hour looking for the button that will "Hide Volume Numbers From Current Traded Volume Columns". Searches kept bringing me to threads that installed the Volume by Price indicator and I couldn't remember the exact wording of the setting so, my guesses on the wording were not resulting in finding this in the Sierra platform.
Anyway. I would love to see this change. The enclosed image explains everything.
The Hide Volume Numbers setting should also be located in the Trade Tab under Chart DOM settings.
Thank you so much for considering this change.
imagePlatform Suggestion_DOM Volume Numbers Setting.png / V - Attached On 2023-02-13 20:05:16 UTC - Size: 89.87 KB - 120 views
[2023-02-13 22:34:41]
John - SC Support - Posts: 39380
We know it can seem a bit odd, but the reason it is under Chart Settings rather than the Trade DOM Settings, is that this is a Chart Specific option. The Trade DOM Settings are not chart specific, but rather are global for all trade DOMs.
