Date/Time: Mon, 21 Apr 2025 17:49:49 +0000
Quote board showing incorrect info on the fields for daily range
View Count: 377
[2023-02-13 19:37:41]
User392433 - Posts: 44
I have attached a quoteboard where the daily range is off by a huge amount. For example: on ES it says the daily range is in the 7000s, when the current price is in the 4000s. I think this also affects the daily range/currency field as well.
Is this a general bug or is there some setting to fix this?
Extra info: I haven't changed the tick size in the default symbol settings.
I am using denali data feed, but I connect to rithmic for apex trader funding.
I have real time data activated for all of CME group.
imageScreenshot 2023-02-13 113150.png / V - Attached On 2023-02-13 19:36:17 UTC - Size: 83.02 KB - 96 views
[2023-02-13 23:46:23]
Sierra_Chart Engineering - Posts: 19289
This has already been resolved in cases where a Price Multiplier is used. Update Sierra Chart to the current version:
