Date/Time: Mon, 21 Apr 2025 17:43:42 +0000
Trades history
View Count: 326
[2023-02-13 15:44:21] |
g4500 - Posts: 27 |
Hi Could you tell me how to have access tp the history of the trade i took? Thx |
[2023-02-13 17:53:39] |
John - SC Support - Posts: 39380 |
As long as the information was collected from your trading service at the time, then all of that information is in the Trade Activity Log. Refer to the information here: Trade Activity Log: Viewing Historical Trade Activity If you are using the Teton Order Routing Service, then your fills are always available, so it will automatically fill in if you do not have it on your local system (such as you removed it). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
