Date/Time: Mon, 21 Apr 2025 17:40:46 +0000
Data
View Count: 309
[2023-02-13 15:21:36] |
User601446 - Posts: 1 |
Hi there, I'm little confused about Denali Exchange Data Feed options. I only need data for charting Gold on Comex exchange. Which one is most cost optimal? By the way, I don't have a future account. Thanks & have a good day! |
[2023-02-13 17:36:48] |
John - SC Support - Posts: 39380 |
If you do not have a live, funded, futures trading account, then the CME Group will not let you get the data at the non-professional rate. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Given the above, the lowest cost option at the Professional rates is the COMEX, For professionals and users without a trading account which costs $127.00 per month. We really recommend the solution outlined at the following link to create an account that will suffice for the CME Group requirement and allow you to pay the non-professional rates (which could be as little as $1.25 per month for the COMEX non-professional top-of-book): Easy Solution to CME Funded Trading Account Requirement Once you have the above worked out, then follow the instructions at the following link to setup the Denali Exchange Data Feed for your CME Group data: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
