Date/Time: Mon, 21 Apr 2025 17:40:45 +0000
rhythmic data
View Count: 425
[2023-02-13 15:16:32]
User257481 - Posts: 38
hi , i have rhythmic data conect to bookmap i can use it my license with Sierra?
i also need the package i can draw volume profile so i need to upgrade?
thank you
[2023-02-13 17:17:52]
John - SC Support - Posts: 39380
You can use Rithmic data with Sierra Chart, but be aware of the issues associated with it and our support policy at the following link:
Rithmic Trading Platform Service: Rithmic Support Policy
The Drawn Volume Profile option is only available with the Advanced packages. So yes, you would need to change your package to the "Integrated Advanced" (Package 11). Follow these instructions to change your package:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
