Date/Time: Mon, 21 Apr 2025 17:52:48 +0000
Sierra chart data connection is down
View Count: 342
[2023-02-13 15:09:22]
User298944 - Posts: 1
My Sierra chart connection to data is down. See log below
Created the DTC Protocol server. | 2023-02-13 14:03:46.268
DTC Protocol Server listening on port 11099. | 2023-02-13 14:03:46.287
Reading Internal Order ID file. | 2023-02-13 14:03:46.287
Reading Trade Orders file. | 2023-02-13 14:03:46.490
Reading Trade Positions file. | 2023-02-13 14:03:46.491
Reading Trade Account Data files. | 2023-02-13 14:03:46.492
UDPListener (1612). Port 22904 | Listening on UDP port 22904. | 2023-02-13 14:03:46.498
Software version: 2459 64-bit | 2023-02-13 14:03:46.498
Primary Thread ID: 14500 | 2023-02-13 14:03:46.498
Usage end date: 2023-03-03 | 2023-02-13 14:03:46.498
Enabled for: Advanced Features 2. | 2023-02-13 14:03:46.498
Enabled for: Sierra Chart Historical Data Service. | 2023-02-13 14:03:46.498
Enabled for: Denali Real-Time Exchange Data Feed. | 2023-02-13 14:03:46.498
Enabled for: Delayed Denali Exchange Data Feed. | 2023-02-13 14:03:46.498
Enabled for exchange2: fairx_exchange.data | 2023-02-13 14:03:46.498
Allow Support for Sierra Chart Data Feeds is enabled. | 2023-02-13 14:03:46.498
Current selected Data/Trading service: Interactive Brokers | 2023-02-13 14:03:46.498
Custom symbol settings values: disabled | 2023-02-13 14:03:46.498
Chart Update Interval: 10 | 2023-02-13 14:03:46.498
Intraday Data Storage Time Unit: 0 | 2023-02-13 14:03:46.498
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2023-02-13 14:03:46.498
2023-02-13 14:03:46 Local computer time in UTC | 2023-02-13 14:03:46.498
2023-02-13 14:03:46 Local computer time in SC Time Zone | 2023-02-13 14:03:46.498
2023-02-13 14:03:47 Server time in UTC | 2023-02-13 14:03:46.498
Local computer UTC time and Server UTC time difference: 2 seconds. | 2023-02-13 14:03:46.498
Program path: C:\SierraChart\ | 2023-02-13 14:03:46.498
Data Files path: C:\SierraChart\Data\ | 2023-02-13 14:03:46.498
OS Version Number: 10.0 | 2023-02-13 14:03:46.499
Locale Setting: C | 2023-02-13 14:03:46.499
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2023-02-13 14:03:46.500
Allowed protected custom studies: | 2023-02-13 14:03:46.500
Crash reporter started: true | 2023-02-13 14:03:46.500
Created the DTC Protocol historical data server. | 2023-02-13 14:03:46.541
HD Server Manager | Listening on port 11098. | 2023-02-13 14:03:46.557
Checking for new symbol settings. Requested symbol settings MD5 for service code interactive_brokers.trading. Request ID: 1. | 2023-02-13 14:03:46.557
Received 5 login tokens. | 2023-02-13 14:03:46.742
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2023-02-13 14:03:46.773
Using Bid/Ask average for last trade price for GBP.USD-CASH-IDEALPRO | 2023-02-13 14:03:46.788
Using symbol data fast lookup vector | 2023-02-13 14:03:46.788
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2023-02-13 14:03:46.814
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2023-02-13 14:03:46.814
Symbol settings MD5 received. Request ID: 1. | 2023-02-13 14:03:48.396
Symbol settings are up-to-date for interactive_brokers.trading. | 2023-02-13 14:03:48.396
Interactive Brokers | Connecting to 127.0.0.1:7491 | 2023-02-13 14:03:52.844
IB TWS socket (1) | Creating socket. | 2023-02-13 14:03:52.844
IB TWS socket (1) | New receive buffer size: 5242880 | 2023-02-13 14:03:52.844
IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2023-02-13 14:03:52.844
Interactive Brokers | Sending API sign: API | 2023-02-13 14:03:53.394
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2023-02-13 14:03:53.394
Service connection timed out. Will disconnect and retry. | 2023-02-13 14:04:52.843 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-13 14:04:52.843
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-13 14:04:52.843
IB TWS socket (1) | CloseSocket call. | 2023-02-13 14:04:52.859
Interactive Brokers | Failed to connect to the data and trade server. | 2023-02-13 14:04:52.859 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-02-13 14:04:52.859 *
IB TWS socket (1) | Shutdown started. Waiting for graceful close. | 2023-02-13 14:04:52.871
Interactive Brokers | Disconnected. | 2023-02-13 14:04:52.871
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-13 14:04:52.871
Interactive Brokers | Connecting to 127.0.0.1:7491 | 2023-02-13 14:04:54.878
IB TWS socket (2) | Creating socket. | 2023-02-13 14:04:54.878
IB TWS socket (2) | New receive buffer size: 5242880 | 2023-02-13 14:04:54.878
IB TWS socket (2) | Connecting to IP: 127.0.0.1. | 2023-02-13 14:04:54.878
Interactive Brokers | Sending API sign: API | 2023-02-13 14:04:55.426
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2023-02-13 14:04:55.427
Service connection timed out. Will disconnect and retry. | 2023-02-13 14:05:54.896 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-13 14:05:54.896
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-13 14:05:54.896
IB TWS socket (2) | CloseSocket call. | 2023-02-13 14:05:54.911
Interactive Brokers | Failed to connect to the data and trade server. | 2023-02-13 14:05:54.911 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-02-13 14:05:54.911 *
Interactive Brokers | Disconnected. | 2023-02-13 14:05:54.911
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-13 14:05:54.911
IB TWS socket (2) | Shutdown started. Waiting for graceful close. | 2023-02-13 14:05:54.924
Interactive Brokers | Connecting to 127.0.0.1:7491 | 2023-02-13 14:05:56.930
IB TWS socket (3) | Creating socket. | 2023-02-13 14:05:56.930
IB TWS socket (3) | New receive buffer size: 5242880 | 2023-02-13 14:05:56.930
IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2023-02-13 14:05:56.930
Interactive Brokers | Sending API sign: API | 2023-02-13 14:05:57.494
Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2023-02-13 14:05:57.495
IB TWS socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-02-13 14:06:52.902 *
IB TWS socket (1) | Socket gracefully closed by remote side. | 2023-02-13 14:06:52.902
IB TWS socket (1) | Closed. | 2023-02-13 14:06:52.902
Service connection timed out. Will disconnect and retry. | 2023-02-13 14:06:56.917 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2023-02-13 14:06:56.917
Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-13 14:06:56.917
IB TWS socket (3) | CloseSocket call. | 2023-02-13 14:06:56.933
Interactive Brokers | Failed to connect to the data and trade server. | 2023-02-13 14:06:56.933 *
Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2023-02-13 14:06:56.933 *
IB TWS socket (3) | Shutdown started. Waiting for graceful close. | 2023-02-13 14:06:56.946
Interactive Brokers | Disconnected. | 2023-02-13 14:06:56.946
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2023-02-13 14:06:56.946
[2023-02-13 16:34:19]
Sierra_Chart Engineering - Posts: 19289
You need to update Sierra Chart following these instructions:
And also update TWS to this version:
TWS version 10.20.1i Jan 18 2023 or higher.
