Date/Time: Mon, 21 Apr 2025 17:55:43 +0000
New Brokerage Account
View Count: 303
[2023-02-13 14:33:55]
User148596 - Posts: 217
Hi, I've just funded a new brokerage account and I'm wondering how to go about getting it connected. The brokerage is Edge Clear and I'm supposed to use Teton. I wasn't sure if I should select Teton CME or Teton FairX. And with both of these options there was no option for adding my Edge Clear account #.
Thanks for your help :)
[2023-02-13 15:01:52]
Sierra_Chart Engineering - Posts: 19289
Follow through the instructions here:
Sierra Chart Teton Futures Order Routing: Setup Instructions
You need to use Teton CME Order Routing.
