Date/Time: Tue, 26 Nov 2024 19:50:40 +0000
Chart Region Overlap
View Count: 1093
[2014-06-10 15:02:01] |
User72407 - Posts: 31 |
I think I fumbled this myself while working on pivot points, but somehow the regions of the 15 minute chart seem to be partially hiding on or more of the others. I can not seem to get them right by dragging the "bar" in the price scale. Two images are attached, note how the 60 min and 5 min look... can not get the 15 back to that. Can you help? Thanks
Chart Region Overlap 2.JPG / V - Attached On 2014-06-10 15:00:43 UTC - Size: 113.86 KB - 358 views Attachment Deleted. Char Region Overlap.JPG / V - Attached On 2014-06-10 15:01:50 UTC - Size: 144.55 KB - 366 views |
[2014-06-11 06:45:37] |
With the proper use of the Adjust Regions tool documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#AdjustRegions You will be able to adjust any of the chart regions. If you still have difficulty, we recommend removing the studies from the chart and adding them again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
