Date/Time: Mon, 21 Apr 2025 17:43:44 +0000
DOM
View Count: 346
[2023-02-13 09:52:44]
scalpertradesv - Posts: 1
Hello ! How to enable market depth in the DOM ?
image2023-02-13_10-23-46.jpg / V - Attached On 2023-02-13 09:51:07 UTC - Size: 90.02 KB - 106 views
[2023-02-13 16:53:37]
John - SC Support - Posts: 39380
The main thing is that you need to ensure that you are setup to get Market Depth from your data provider. In this case, you are using Rithmic, so you need to check with them to see if you are setup to get the Market Depth data.
If they state that you are properly set up, then go through the following:
File Menu: Not Receiving the Full Number of Market Depth Levels
