Date/Time: Mon, 21 Apr 2025 18:01:42 +0000
Volume
View Count: 326
[2023-02-13 00:39:24]
User377189 - Posts: 215
Which is most accurate study for volume? Looking for total intraday volume and volume on individual candle on time based chart.
[2023-02-13 16:34:26]
John - SC Support - Posts: 39380
Any of the studies will give the same results. The data is the data. So if you just want to see the volume per bar use the Volume study.
The one thing to be aware of is that Daily Historical data and Intraday data give different volumes as the exchanges do this. Refer to the following:
Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume
