Date/Time: Mon, 21 Apr 2025 17:43:43 +0000
Find fast tpo profile extended line price
View Count: 378
[2023-02-12 16:22:58] |
awakef - Posts: 72 |
Hi there's a way to find fast the price of the tpo extended line like the circle on the picture without scrolling back. Since it takes long time scrolling until you find it. Date Time Of Last Edit: 2023-02-12 16:23:39
[2023-02-13 16:08:40] |
John - SC Support - Posts: 39380 |
Use the Value Label option for the extension subgraph. Refer to the following: Chart Studies: Subgraphs Tab >> Name and Value Labels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-13 17:21:46] |
Thanks John! But what I really meant was to find the date from where the extension line is from. Since it takes long time scrolling back to see from what date is from and also scrolling back messes the interactive scale and the scale doesn't stay at the same price scrolling back. |
[2023-02-13 17:58:50] |
There is not a way to mark the line with the specific information of the TPO profile that generated it. With regards to the scaling, you can stop the scale from adjusting as you scroll to make it easier find the profile you want, by right-clicking on the scale and selecting Scale Range: User Defined with Auto Set. That will keep the scale as it is at that moment. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-14 17:02:18] |
Thanks for the info. But John can you add the feature to have also date labels. I don't mind paying for that. Date Time Of Last Edit: 2023-02-14 17:02:56
[2023-02-14 17:16:13] |
We have noted the feature request, but we can not say when we can get to it. We wish we had time to take on paid work like this, but we simply do not right now.
[2023-02-14 17:22:40] |
Ok thanks for all the help like always!
