Date/Time: Fri, 29 Nov 2024 10:20:44 +0000
Changing Date range in file has no effect
View Count: 353
[2023-02-12 16:08:18]
HeyUgly - Posts: 247
Picture attached.
Im using numbers bars with a weekly chart in CLH3
the Weekly is showing a starting day of 12/01/2022 which is a friday
Im trying to change it to sunday so the weekly candles are correct
When i change it, Nothing happens. This happens time to time with stock charts
when i do change it, it works fine.
This time it is not. Yes the number bars are set to intraday only etc.
When i change the date here, in the box circled, nothing happens and goes back to 2022-12-01
Please advise
Thanks!!
imageCapture.PNG / V - Attached On 2023-02-12 16:08:07 UTC - Size: 31.69 KB - 76 views
[2023-02-12 17:36:19]
User431178 - Posts: 544
Try setting the date(s) listed under the heading Load Data Limiting Method: Date Range
Date Range From
Date Range To
Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu)
