Date/Time: Mon, 21 Apr 2025 17:46:49 +0000
HotKey for switching FIFO and LIFO
View Count: 420
[2023-02-12 14:51:37] |
jrob - Posts: 22 |
Hello, Is there a hotkey available for switching Open Position Average Price? I looked and didn't see one, but wanted to make sure I didn't overlook something. If not, is there a way to navigate the sub-menus (Symbol, Data Limiting, Bar Period,...) under Chart Settings with a hotkey? I tried TAB and right\left arrows, but that did not work. I am exploring building a macro if no direct hotkey for Open Position Average Price is available. |
[2023-02-13 00:41:44] |
Sierra_Chart Engineering - Posts: 19289 |
No this is not supported, but refer to the Keyboard commands that can be used with the new Settings Windows: Settings Windows Interface: Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-02-13 00:42:08
