Date/Time: Tue, 22 Apr 2025 07:05:49 +0000
Enable PriceSquawk for account
View Count: 359
[2023-02-11 18:36:47]
User152129 - Posts: 27
Can you activate PriceSquawk for my account? Thanks
[2023-02-13 15:40:52]
John - SC Support - Posts: 39395
User152129:
This has been done.
[2023-03-02 16:07:55]
Dear John,
Where can I check whether my PriceSquawk service is active or not? Regards
[2023-03-02 18:10:09]
There is not a way for you to check if your Sierra Chart is enabled for PriceSquawk or not. You would just have to test it with them to see.
Or you can ask - and in your case you are already enabled.
