Date/Time: Tue, 26 Nov 2024 19:50:45 +0000
synchro time on charts
View Count: 1500
[2014-06-10 13:26:04] |
User30743 - Posts: 365 |
how do i sychro the time on charts? i have four charts in one chart book (the left side of the screen http://www.sierrachart.com/image.php?l=1402406804361.png ) and orderflow (the right side of the screen) and it shows different time. the left side is odd-numbered the right side even-numbered. why is that so? and how do i make it the same? Date Time Of Last Edit: 2014-06-10 13:26:55
[2014-06-10 16:44:19] |
Are you referring to the timescale at the bottom of the chart? Look at the time at the top line of the chart. If that field is not present you can add it through Global Settings >> Customize Chart Header. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
