Date/Time: Mon, 21 Apr 2025 17:34:53 +0000
Study: Trading the Nines
View Count: 376
[2023-02-10 21:03:25] |
User688525 - Posts: 284 |
Hello Sierra Chart, Is it possible for the "Trading the Nines" study (Trading the Nines) to have a variable "Bar Formation" value, so that instead of this being fixed to "9", it can be adjusted to another number? Can this be added as a feature request/modification to the existing study, or is the source code available for this study to this separately? Thank you Date Time Of Last Edit: 2023-02-10 21:07:27
[2023-02-10 23:19:12] |
John - SC Support - Posts: 39380 |
We take note of all feature requests, but we can not say when we will be able to get to any particular item. The source code for this study is available in the Studies6.cpp file in the ACS_Source folder under your main Sierra Chart installation folder. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-11 06:34:36] |
Thank you John. I located the source code: "/*==========================================================================*/ SCSFExport scsf_TradingTheNines(SCStudyInterfaceRef sc)" |
